SOLD 1965 fury
In need of tail light surround trim that mounts on the ends of the rear fenders and goes around the outer tail lights - both sides. Could use un-dented trunk trim pieces that mount above and below the trunk plate.
I know it's an old post, but I need the shifter needle that tells you what the transmission is in. I could also use the 65 SpeedO as well.
Would you happen to have a steering wheel with the horn rings and center cap? Also the push buttons for the a/c? Thanks
What do your dash trim pieces look like?
Full pieces required left to right...
Actually, it seems as if the seller is still active and possibly selling parts based on his PM's. If not, he should close the thread. Maybe make a post either way to clarify.
Will get back to all who have posted. Havent looked at this for a long time, just answeringthe email messages.
