SOLD 1970 Fury dash courtesy light
70Tom
Phoenix, AZ
I'm in need of the dash courtesy light housing that is shown in the picture below. That panel being shown in the pic is the one that goes beneath the dash pad just above the speedometer cluster.
I can't tell from your picture but is this the panel you are looking for?
Yes I believe that is the same panel. Specifically I'm looking for the silver housing in the pic I posted. Although if the price was right I might buy the panel as once of the corners on a blue light cover is cracked off of mine.
Will a 71 Chrysler be the same
That I am not sure of. I'd have to see a pic and compare. However as noted in the last post, I'm just looking for the silver housing of the courtesy light that shines downward on the dash panel. (See pic I posted)
I'm pretty sure I have that. From one of the fussies I parted
Well Bob, it looks like it's up to you. haha. (fingers crossed)
Struck out also. I found the panel. Mine doesn't look the same so not sure if mine had the same map light.
