errick51
This is a set of four wheels I took off of my New Yorker. They are very clean steel 15"s that originally were on a B Body, but with 215/75 R15s fit the C Body perfectly. The radial tires are mounted on the rims and all wheels are static-balanced with the weights on the backside. The tires only have about 2500 miles on them with uniform wear. The tires are very close to the outer diameter of the original wheel for speedo concerns. The whitewalls are a little over an inch wide I believe. I need the space. Zip code is 48304 or can bring to 48124 area as well.
$475 for the set.
email Steve
$475 for the set.
email Steve
