1970 B5 Sport Fury GT...Critters folly....back to basics
little cleaner...
things done...things in waiting..things in progress...rollin along singin a song
things woulda went quicker if l had remembered the torque convertor bolts...its been awhile...rookies....
tranny was built March 5/70...1 /3600 built that day....musta been a few lines goin lm thinkin to keep up
That is your speedometer gear housing. Depending on your rear end gear ratio and tire size the gear inside that housing would get changed out to the one listed in the FSM. Every gear is labeled with the tooth count. Depending what tooth gear you have you would line up the range marking with the boss on the transmission case.
welp another long day in the dungeon.....time to change filter...wasn't sure what to expect..was easy thankfully...even learned a little about these trannys from Graham this am...honestly if it wasn't for Graham and Tobias my boat woulda been sunk long ago me thinks,,,thanx fellas
lotsa crud stopped ..good thing l decided to crack case and have a boo...cleaned it all up carefully to keep **** from fallin in
may have to look into a magnet if l can find one......new wix filter...bigger than one that came out..
after having a look at a cpl pics l posted last night had to go back over the tranny and clean up a few areas once filter was in ect...used a plastic reusable pan gasket from Chrysler..sorry no pic..anyway time to button things up..
:eek:
managed to clean up starter today as well..
ready to go..
Had some time to prep back of block so when l slap it on the engine stand its done..
whats is this used for..tie down?Refrence
refrence
bloody adds fuckin things up...srry for duplicates'
slapped some high temp silicone for peace of mind..
tapped off tranny to block contact areas to ensure good grounding
slapped a cpl coats of paint on it...
not worried about heads or intake as they will be replaced with others..cleaned up and painted my old nemesis the tourque convertor bracket and bolts..will throw those on tomorrow once l sort out the tourque specs...will add locktight to the bolts as well for piece of mind..
for those that don't have these..
That's tranny done and ready to install...on to the block tomorrow
That's all folks....nighters
I have that same goofy bracket (picture # 8, post 427) on the back of the LH head on my GT. Was wondering what it was for myself.
This is probably a little late, but since you were in the transmission to change the filter. Did you manage to adjust the bands? the FSM outlines the procedure and it is fairly easy. Might as well try it since the transmission is still out of the car. it can be done in the car, but doing it on a transmission stand looks a whole lot easier than under the car on your back.
was reading a tad on it buthought it better l leave it alone..outa my ballpark on this one...doin some stuff that's new to me so never say never...may revisit the tranny before l connect it back to the block...would have to school myself on the procedure......have new respect for tranny mechs...
bin busy..
throwin everything in here for refrence ect..if l need somethin l can find it fast..
