Caxtonia
What: a 1958 Chrysler Windsor 4 door sedan. It runs and drives but needs a bit of work. Particularly, new tie rod ends and correct wheels (the wheels on it aren't original, they were replaced by a previous owner from multiple different other Mopars). The front floor pans are rusting out and need replaced, the oil pressure gauge doesn't work (but the car has good pressure and doesn't leak much oil, you won't need to fill it between oil changes), the rear panels have rust and the trunk floor is rusted out on the sides. The Neutral button on the shifter doesn't start the car anymore, you can see a substitute that was wired in under the dash. It has the original 354 V8 Spitfire motor and transmission.
Where: this vehicle is located in Rapid City, South Dakota. If you aren't located in Rapid City, you'll need to arrange for transportation to get the vehicle to its new home.
How Much: my asking price is $5,500. I'll consider any trade offer made, but I would much prefer to sell it outright. The car does have a clean title.
Pictures:
Pictures:
