1. Jayvan1967
    Jayvan1967 New Member
    10
    1
    Apr 24, 2018
    Nebraska
    Have a 1963 Chrysler Newport. Been sitting for 25 years. Transmission shifts good into reverse, 1st and 2nd. Does not want to shift into 3rd gear. Fluid is at the right level. Searched other forums and it seems the most common failure would be the seal on the 1st/reverse servo. It that the place to start? In research, it seems the older 727's have a different servo and takes a different seal. Any place have this seal? Thanks
  2. Pete Kaczmarski
    Pete Kaczmarski Senior Member
    2,552
    1645
    Oct 11, 2012
    Waupun WI.
    First, make sure the push button shift cable is adjusted properly. Look at the factory service manual.
    • Agree Agree x 2
  3. mikedrini
    mikedrini Well-Known Member FCBO Gold Member
    545
    275
    Oct 9, 2017
    Center Barnstead, NH
    I agree with @Pete Kaczmarski in that I have a 64 (essentially the same setup) and the throttle linkage arm that connects to the carburetor needed to be adjusted.
  4. Jayvan1967
    10
    1
    Apr 24, 2018
    Nebraska
    I will look at the shift cable. I have noticed that when I take it out of park, it will sometimes want to creep forward when it is in neutral. thanks
  5. Pete Kaczmarski
    2,552
    1645
    Oct 11, 2012
    Waupun WI.
    You will also need the car on a hoist or off the ground with a knowledgeable person inside working the pushbutton and the other with the cable adjusting it accordingly.
  6. 413
    413 Well-Known Member
    855
    266
    Jan 28, 2019
    NW USA
    If you have no 3 rd gear it has nothing to do with low/reverse piston. And you have reverse working so it’s not that.
    • Agree Agree x 1
  7. Davea Lux
    8,374
    2012
    Mar 27, 2017
    Cornelius Or
    I would be inclined, after the proper adjustment checks have been made to the kick down linkage, to pull the transmission pan and see how much crud is on the bottom of the pan. A car that has sat for that long may have picked up considerable moisture that has turned to sludge on the bottom of the transmission pan. This in turn may have clogged or partially clogged the transmission filter leading to low operating pressure. Change the transmission oil filter and fluid and do a band adjustment to see if that helps. Be advised that this car may have been parked 25 yeas ago because the high gear had failed, in which case you are probably headed for a rebuild.
  8. 413
    855
    266
    Jan 28, 2019
    NW USA
    Yes could have dropped 3 rd gear and was parked because of it.
    Band adjustment is a waste of time for no 3rd gear.
  9. Davea Lux
    8,374
    2012
    Mar 27, 2017
    Cornelius Or
    True, but as long as the pan is off, why not do it?
    • Agree Agree x 1
  10. Davea Lux
    8,374
    2012
    Mar 27, 2017
    Cornelius Or
    Might also want to check to be sure all of the valve body bolts are tight.
  11. 69monaco
    69monaco Senior Member
    3,321
    2876
    Feb 1, 2014
    (NL)
    @Jayvan1967
    Today i adjust the shiftercable of my 63 plymouth SF , it also moved slowly forwards in neutral.......
    I took the bolt out the adjusting wheel ;turn it loose (2 holes against the clock).
    Now the car moves backwards..........in neutral.
    So i took the bolt out again and turned the adjust wheel 3 holes clockwise...............!!!!
    Now it,s perfect ( i guess ) ; no moving forward or backward in neutral .
    tKBZBrQy2rHc9Wj1j1XUsaOPV55aH85ZW6_fdNChUPQNafwvAU7ExscsghZuLcUObf4IusMS6UoKzjXuiPM0OQDmQMyUw-HA.jpg
  12. mikedrini
    545
    275
    Oct 9, 2017
    Adjusting the shifter cable is SO much easier with the tranny pan off and being able to look up and in.
  13. 69monaco
    3,321
    2876
    Feb 1, 2014
    (NL)
    Probably if you know what you are doing and did it before , yes i guess .....:)
  14. mopar440
    mopar440 Well-Known Member
    655
    182
    Oct 17, 2018
    St paul
    When this has happened to me ( twice) I drove then for a bit, using varying pedal pressure to try and get it to shift. Then let it cool down and repeat. Repeat 3-4 times, worked for me ! New fluid too, good luck!
  15. Jayvan1967
    10
    1
    Apr 24, 2018
    Nebraska
    I adjusted the throttle linkage how the service manual tells you. When I shift it manually from 1st to 2nd to drive it does shift to third now. The shift to third seems to be really soft compared to the 1st to 2nd. But it is shifting. I will be trying to adjust the shift cable in a couple of weeks and I will let everyone know the outcome. I had previously changed the fluid and the amount of crud in the pan was not too bad. thanks everyone
    • Like Like x 1
  16. 69monaco
    3,321
    2876
    Feb 1, 2014
    (NL)
    But it still moves forward in neutral i gues ?
