NOT MINE 1963 Dodge Polara 2-dr "Super Stock Tribute" 440 auto $44k CAD / $32k USD Stratford Ontario
MoPar~Man
Ontario, Canada
$43,900
Description
-VIN Number 2!
-Super Stock Tribute
-Lots of Invoices and Paperwork
-1967 440ci Engine with Dual Quad
-Dual Edelbrock 600 CFM Carburetors
-727 Automatic Transmission
-8 3/4 Rear End with 3.93 Gears
This special 1963 Dodge Polara Super Stock Tribute is the second Dodge Polara produced! Sequential VIN # 100002. The car has been restored and improved over the years. Lots of paperwork is included with the car including invoices dating back to 1997. This Dodge has a strong running 1967 440 cubic inch engine with dual 600 CFM carburetors mounted to a dual quad aluminum intake manifold. The engine also features a Milodon deep oil pan, aluminum water pump, new alternator, and 3 core radiator.
The exhaust headers are 2.5” ceramic coated TTI. The exhaust is a TTI 3" X-pipe ceramic coated front to back with Flowmaster mufflers. The car sounds great! The transmission is a 727 automatic. The 8 ¾ rear end has 3.93 gears. The brakes are Wilwood discs up front and drums on the rear. The battery has been relocated to the trunk as a Super Stock car would be. The car has not been tracked in over a decade, however the paperwork indicates that a previous owner was an NHRA Tech inspector in Michigan. He would drive the car to the track, run 13.2 passes in it, then drive home stopping for ice cream on the way! The engine is smooth running and easy to start. It is an excellent car to drive on the street! The body is straight with good gaps. The paint is very good with few flaws to be seen. The car has excellent glass all around and lots of new weatherstripping. This Polara has welded subframe connectors which help it handle the power. The chrome and brightwork are very good throughout.
Most of the trim appears new. The interior is beautiful! It is presented in Red and White vinyl. The headliner is perfect, the dash shows no cracks or fading, the carpet looks new, the door panels are excellent, the seats show no wear. The steering wheel is excellent with no cracks or wear. The car has auxiliary gauges mounted neatly under the dash and a Moon Racing tachometer is mounted on the top of the dash. A Kenwood AM/FM radio is tucked under the dash and a CD changer is located in the trunk. The gauge cluster is clear and the gauges function properly. This Polara rides on 15” steel wheels in the rear. The rear tires are 28 x 11.50 Mickey Thompson ET Street and the fronts are 26 x 8.5 Mickey Thompson Sportsman with 15 inch Torque Thrust wheels.
