I doubt that repops are available, if they are similar to the 67-70+ actuators.No a/c. I will pull the actuator and see what model it may be.
Are there re-pops for these?
Agree. Need that part # from detmatt. Then ebay adventure. I looked on Hemmings classifieds but found almost nothing for Chrysler in their classifieds. HVAC Service and parts were slim to none.I doubt that repops are available, if they are similar to the 67-70+ actuators.
The ones that I have looked at aren’t marked with a part number. The factory parts book will list the part number and with your existing part, you should be able to identify a matching part from the pictures that sellers post on their ads.
You should be able to ‘patch’ that with RTV. Let it dry / cure before exercising it. You may want to clean it with denatured alcohol before applying the RTV.View attachment 557552
Disassembled the actuator and found the problem. Now an attempt to fix it with some RTV.
will keep updated
Thanks! Looking forward to a success story!View attachment 557552
will keep updated
Great work!So I used this old set side cutters to open the actuator. I have had them forever and don't even know where I got them.
Sealed the diaphragm with some RTV and let sit overnight. I also thought about some rubber vulcanizing glue, but the RTV filled the gap nicely.
Scotch brite the shaft and lubed all moving points with Syl-Glyde.
assemble and bench test with a mity-vac
Finish dollying the lip down and whizzer wheel the burrs off. It didn't come out as nice as I would have hoped but I didn't want to keep working the thin metal and ruining it.
SUCCESS!!! Installed and working as it should.
Excellent! Great craftsmanshipSo I used this old set side cutters to open the actuator. I have had them forever and don't even know where I got them.
