SOLD 1965-1968 C-Body Clutch Pedal Assembly with Extras
hyde-park
Midwest
I have a clutch pedal assembly from a 1966 Fury I for sale. Originally from a /6 three speed on the column car with MANUAL brakes. To my knowledge this will fit all 1965-1968 c-bodies cars. The clutch z-bar will have to be shortened 3/4" in width to work in any V-8 equipped car, small or big block. Included is the pedal assembly with firewall reinforcement plate, brake light switch, master cylinder push rod mounting bolt and nut, z-bar, threaded lower linkage adjustment rod, thru firewall pushrod, both ball mounting studs with the 4 plastic bushing halves (intact), and the z-bar frame rail mounting bracket. Also included as extras are the speedometer cluster with the "Plymouth" logo replacing the PRND21 if the vehicle was equipped with any manual trans or had a floor shifted automatic and finally a clock delete block off plate. I have no idea if the speedo works as this was from a non running vehicle but it looks to be complete and undamaged. I am asking $500 plus shipping from my 50501 zip code.
I have no idea why the pics were included twice. I can't seem to edit out the extras from my ad. Sorry for the confusion. If the mods can remove the duplicate pics that would be a plus, Thanks!
