For Sale 1965/68 Chrysler tilt and telescopic wheel and column 350.00
straightjob
Northern New Jersey
For sale: 65/68? C body tilt telescopic wheel and steering column 350.00 best offer .
I hve a tilt telescopic column i was going to use in my 65 L coupe but going to leave it be let me know if interested thanks
Probably a '68 because of the padded center cap? In which case it also has the collapsible outer tube? Would it even work / fit in a '65 or '66 ?
I don't think so - the padded centre caps are all the same 66 - 68.
Having dealt with many of these columns for my Chrysler T&C and my 66 Monacos, I'm very sure that this is a 66 T&T column, as it has the correct dash collar. It would fit perfectly in a 65 or a 66, even though 65s were tilt only, and would need modification to fit any other C bodies and other years because of the collar.
I do not see the collapsible column mesh on this one, which also tells me it's a 66 column. Furthermore it has the cable actuated turn signal with the switch down at the bottom of the column on the outside, which changed to a more traditional "inside under the wheel" version in 67 or 68.
