WILLIAM COWGER
1965 C-BODY DODGE POLARA,MONACO,CHRYSLER NEWPORT,300,NEW YORKER,PLYMOUTH FURY,SPORT FURY 361-383-413-426SW engine mounting brackets,motor mount insulators,nuts,bolts,washers.
2 original steel engine mounting brackets,media blasted,powder coated satin black
nos pass side motor mount insulator#2402182 with correct mounting nut/washer combo
original used, in exc, drivers side rubber motor mount insulator#2465861 with correct nut/washer combo
correct bolts,nuts washers to atttach the steel brackets to your engine block(must have front mounted drilled&tapped bosses )with recessed heads, thick washers and H stamp
2 front attaching bolts with thick washers
will only fit 1965 C-body with a big block 361-383-413-426street wedge
$300.00
[email protected]
$300.00
[email protected]
