1965 Chrysler 300 what other carand year body and trim are interchangeable?
Early C Bodies - The Slab Side Years
  1. Lieggi26
    Lieggi26 New Member
    36
    23
    May 18, 2019
    New Castle, Delaware
    please help.
    Also looking for emblems for 1965 Chrysler 300
  2. Zymurgy
    Zymurgy Old Man with a Hat FCBO Gold Member
    6,137
    4681
    Sep 14, 2012
    London, Ohio
    The upper exterior side trim is the same all 65-66 models I reproduce the clips that hold that trim in place. Everything else externally I believe are model and year specific.
    However you could put any lower side trim from any model of 1965 or 66, but would not technically be correct.
    I have the clips to hold on the lower trim for 1965 New Yorker and 300L 1966 Nyer and 300.
    Hope that helps, they were very specific. The front fender would be the same from 2 door to 4mbut then you would need them trim for model number of doors.
    • Like Like x 1
    • Thanks! Thanks! x 1
  3. Lieggi26
    Lieggi26 New Member
    36
    23
    May 18, 2019
    You won't have the trim piece on the front passenger side the trim before the blinker indicator. It's a 90 degree bend
  4. rexus31
    rexus31 Senior Member
    2,554
    1269
    Jan 7, 2011
    San Gabriel, CA 91775
    The “end” pieces are specific to the ‘65 models and are the same across the Newport, 300, 300L, New Yorker and Wagons.
    Which emblems are you needing? Quarter panel, grill, interior door panel?
  5. rexus31
    2,554
    1269
    Jan 7, 2011
    There are a fair amount of parts on the ‘65’s that are one year only.
    • Agree Agree x 1
  6. Lieggi26
    Lieggi26 New Member
    36
    23
    May 18, 2019
    Grill and quarter panels both sides. Restoring this car
  7. rexus31
    2,554
    1269
    Jan 7, 2011
    I can’t help you with the grill emblem but can restore your quarter emblem cores.
  8. Lieggi26
    Lieggi26 New Member
    36
    23
    May 18, 2019
    What is ur business info? And how much would you charge?
  9. rexus31
    2,554
    1269
    Jan 7, 2011
    PM sent.
  10. Zymurgy
    6,137
    4681
    Sep 14, 2012
    London, Ohio
    I don't have any of the actual trim pieces. @rexus31 is the expert on the 65 and was an immense help on my 66
  11. John Kirby
    John Kirby Member
    90
    20
    Jun 3, 2016
    Minneapolis , Mn
    The upper quarter trim (2 dr) is different in length between 65 & 66. I know I bought the piece off the left quarter from a 65 several years ago to replace my bent one. Didn't fit my 66 Nyer. I might have it sitting in the garage somewhere. Took me several years to find one that was in great shape for the 66 year. You could cut down a 66 piece but the 65 definitely is too short for a 66. 2 dr models are a lot rarer than 4 dr models. Think twice before mangling a piece of 2 dr trim. The clips that hold them on are the same.
