1965 Imperial Front Wheel Hub Bore
Wile E Coyote
Super Genius
Maryville, Tennessee
Does anyone know the hub bore diameter for the 65 Imperial? I assume front and rear are the same since wheels can be moved front to rear.
Any problems with using non hub centric wheels? Thanks!
You really should use what the car was designed to use. Hub centric or Hub piloted requires the hub to center the wheel on the axle center. Stud piloted, or coarse, use the studs to center the wheel and generally use a different lug nut design as well. There are spacers made for wheels with the wrong bore size, but whether or not they are made for your size, I don't know.
