1965 New Yorker Dash pad repair..anyone use this putty ?
Early C Bodies - The Slab Side Years
  1. emmd61
    emmd61 Member
    176
    101
    Dec 5, 2015
    north carolina
    Hi. Still working on my 1965 NYer wagon and progress is slow but positive. I have the seats out now and thinking of doing the cracks in the dash....which are not too bad. I think I read that you have to pull the windshield to get dash out. Is that true? Has anyone used this dash putty? I would prefer not to pull windshield. 169795292_5326838634055987_5179953736194296379_n.jpg 169084848_284269983141708_3906256586853367019_n.jpg
  2. The Goose
    The Goose Senior Member
    2,208
    2926
    Nov 21, 2016
    Santa Clarita ca
    Say the same on my 1969 BUT if you use a flexible extension you can remove the nuts against the glass and then yank the dash with the windshield in place. Look up ABC out of kingman - Bob has some how to’s on pulling dash pads on his Company site.
  3. Ross Wooldridge
    Ross Wooldridge Senior Member FCBO Gold Member
    3,639
    1152
    Apr 25, 2016
    Scotland, Ontario, Canada
    The pad should come off without requiring the removal of the entire dashboard assembly. It's a fiddly job, but can be done in car.
    Do you have the factory service manual?
    Personally, I've never had experience with any of those filler materials.
  4. sprice
    sprice Member
    140
    21
    Dec 7, 2011
    Winnipeg, Manitoba
    I did my the dash on my 68' 300 so cannot comment on pulling the windshield. I can tell you it took me about a year to get it right and mine was quite minor. The problem I ran into was experiencing the various expansion/contraction properties of the factory covering and this (or any) repair material. I would apply according to instructions, light sand to what felt level. Then over some days of leaving this project and attending to other work, I noticed the areas of repair would be raised or cracked. I could only relate this to a temperature change. Over the course of time, I would patch, sand and place in sun and in cool garage , eventually winter. I almost gave up on it when I placed it outside in the sun and the repair points raised yet again. I sanded smooth, primed again, painted, placed in the sun again, no movement. Thought I better wait for winter to see if it would contract and so far, no issues. I am still working on the rest of the car so "no real world out there kind of experience" however happy so far. I did purchase a cover to place on the dash to not push my luck. Polyvance video makes it look quite easy. Other thing I would recommend is using the flexible primer and paint. I could not tell if the material shifts were from original dash covering, putty, primer or paint but suspect they all need some flexibility due to temp changes. If this is going to be fun car show driver then would probably try again. If the dash is for show stopper, 7-10 grade kind of thing, I would look at the professional businesses that recover dashes.
  5. CBODY67
    CBODY67 Old Man with a Hat
    5,965
    1353
    Mar 27, 2011
    Putting a flex agent into the pre-paint paint mix is important. As in flex agent + acrylic lacquer to do the color on GM padded dashes (pads replaced after the outer surfaces curled where they attached to the base structure, as in my '77 Camaro and similar). Not unlike adding the fle agent to the paint sprayed onto the "rubber bumper" fascias in the later 1970s and later.
  6. 69PHOENIX
    69PHOENIX Member
    154
    79
    May 27, 2019
    Mystical Land of OZ
    Hi Fellas,
    Don't mean to Break into the Conversation, BUT, Can Anyone Give Me a Recommendation of What to Use Before the Dash Cracks?
    I have had the Unfortunate Experience of Using a Proprietary Brand on a Dash Pad & the Result Actually Looked like the Product Caused the Pad to Crack even Worse.
    Many Years ago used to use Medicinal Glycerine (I'm working on Memory Here, So Extreme Care Please) Gently, Very Gently Massaged into the Pad on a Nice Warm Day.
    I'm Guessing Modern Technology has Provided a More Suitable Solution Since Those Long Gone Days. (Hopefully)
    The Pad on My Car is in Pretty Good Nick & I'd Like to Keep It That Way.
    Any Suggestions?
    T.I.A. Tony.M
  7. The Goose
    2,208
    2926
    Nov 21, 2016
    Santa Clarita ca
    From e body experience I’d say loose any metal hardware attaching speakers, speaker grilles etc. they always seem to crack where these dang metal bolts/screws are heating up. When I finally install my new (old) 1969 dash pad I’m first removing all the extra hardware speakers etc and I’m thinking I’ll use nylon nuts instead of metal. They won’t last forever but we can do what we can to help em survive.
    PS NO armorall ever. Never.
  8. 69PHOENIX
    69PHOENIX Member
    154
    79
    May 27, 2019
    Mystical Land of OZ
    "The Goose"
    Forgive Me, My Old DA had a Saying "You Don't Have to Have a Long Neck to Be a Goose"
    You have Bought Back Fond Memories.
    I was being Polite in Not Mentioning the Brand Name thinking maybe I was just Unlucky, But Yes I would Agree Not Ever Armorall!
    Thanks for the Advice, I can See the Sense in It.
    Kind Regards, Tony. M
    • Like Like x 1
    • Agree Agree x 1
  9. 3C's & a D?
    3C's & a D? Senior Member
    1,462
    472
    Oct 27, 2015
    By the tree in Edmonton
    Formula 303.
    • Agree Agree x 1
  10. 68PK21 440.6bbl
    68PK21 440.6bbl Old Man with a Hat
    5,914
    3495
    Nov 29, 2017
    Siren City
    I was thinking about something like this when I saw a ad for a car with a Grand Canyon sized crack. FFS put some bondo in that crack came into my mind.
  11. SGT FURY
    SGT FURY Well-Known Member FCBO Gold Member
    962
    800
    Nov 18, 2019
    Northern California
    I believe I have a red uncracked dash pad out of a 65 300. I dig it out and post pics if your interested?
  12. mopar440
    mopar440 Well-Known Member
    621
    179
    Oct 17, 2018
    St paul
    No armorall? What happens? What do you use?
  13. patrick66
    patrick66 Old Man with a Hat
    5,189
    2576
    Jul 4, 2012
    Central Oklahoma
    NEVER use Armor-All or any other silicone-based "preserver" on any automotive application! They end up making that surface even more prone to decay and cracking. Vinyl tops and dash pads are especially prone. All I use is a soft, wet cloth with light soap (NOT Dawn or other oil-absorbing cleaner!!!). Wipe the surface clean, then take a damp, soft, DRY towel to dry the top or dash. That's all. Period. I've used this technique on my 1966 Coronet, which has the ORIGINAL pad which is crack-free, and its vinyl top, which was replaced in 1984 before I had the car painted. It's still as perfect as the day it was installed.
    No silicone. No trendy cleaners or "preservatives". Keeping your car garaged or covered helps immensely, too. If it stays outside all the time, ozone is the worst enemy of your car interior (any material!), tires, and all other rubber seals and surfaces.
    • Like Like x 1
  14. SGT FURY
    962
    800
    Nov 18, 2019
    Northern California
    I just sold dash pad to local 65 owner who saw it listed here on this post!
    I remember reading in a body shop industry magazine where the biggest complaint of painters was when owners wash there cars before bringing them in for paint and armor all tires and interior. Causing the paint to fish eye everywhere.
    • Agree Agree x 2
  15. 69PHOENIX
    69PHOENIX Member
    154
    79
    May 27, 2019
    Mystical Land of OZ
    From Ancient Times Once More,
    For Vinyl Tops We used to Clean thoroughly & Then use Boot Polish.
    Looked Brand New.
    Tony.M
    Very First Question our Panel Beating Teacher Asked the Class.
    "What's the First Thing you Do before Washing a Car Ready for Painting?"
  16. Ross Wooldridge
    3,639
    1152
    Apr 25, 2016
    Answer - "wash it again, sir."
  17. 69PHOENIX
    69PHOENIX Member
    154
    79
    May 27, 2019
    Mystical Land of OZ
    Actually, It Was...
    Close the Windows! LOL
    Tony.M
  18. Ross Wooldridge
    3,639
    1152
    Apr 25, 2016
    Duhhh.... of course! I mis-read the question, and was focussed on the need for things to be extra clean when painting.
  19. 69PHOENIX
    69PHOENIX Member
    154
    79
    May 27, 2019
    Mystical Land of OZ
    Don't Worry,
    You Weren't Robinson Crusoe.
    Regards, Tony.M
