1965 NYer 413 or 383 code 99 engine
Early C Bodies - The Slab Side Years
  1. emmd61
    emmd61 Member
    114
    48
    Dec 5, 2015
    north carolina
    Hi,
    I have a 65 NYer with below fender tag. I think its a 413. Fender tag says code "99" under AB. Appreciate any insight. Happy holidays to all.
    Arthur
    Raleigh, NC
  2. 300rag
    300rag Grumpy Old Man With a Hat FCBO Gold Member
    11,290
    12009
    Dec 4, 2010
    Calgary, Alberta, Canada
    65 New Yorker are all 413. 99 is the standard engine.
    • Agree Agree x 3
  3. Davea Lux
    5,259
    1374
    Mar 27, 2017
    Cornelius Or
    If in doubt if you still have the 413 in the car, there is a machined pad opposite the distributor that is stamped, usually with the numbers 41 or 413 if it is a 413 engine. You can also check the block casting numbers and the block casting date to verify.
  4. jollyjoker
    jollyjoker Member
    159
    64
    Nov 15, 2016
    Ohio
    Agree. Definitive answer is stamped on pad top of engine block. Should read: A413, followed by date code.
  5. jollyjoker
    jollyjoker Member
    159
    64
    Nov 15, 2016
    Ohio
    Sorry Dave . . . you beat me to it!
  6. Lefty71
    Lefty71 Active Member
    218
    82
    Mar 17, 2018
    Ohio
    Still just A41 in '65 isnt it??
  7. Davea Lux
    5,259
    1374
    Mar 27, 2017
    Cornelius Or
    A lot of them were stamped A41, for what ever reason the 3 was left off. That is a 413. That was true of some of the older 413 engines as well. My '64 300 is just stamped 41.
  8. jollyjoker
    jollyjoker Member
    159
    64
    Nov 15, 2016
    Ohio
    Will need to double check tomorrow, but pretty sure my 65 is stamped with the full A413. The switch came in 1965, but I'm guessing that some of the early installs may have been using up some earlier blocks that still had the A41 code.
  9. Verse
    Verse Member
    85
    34
    Jan 14, 2019
    Edmonton Canada
    After looking at a lot of fender tags, it appears that many were just stamped 99 for no particular reason. It may have been the default for one plant.
  10. 69CoronetRT
    69CoronetRT Senior Member
    1,793
    1085
    Feb 3, 2013
    see post #2.
    All codes have a reason.
    Code 99 in 1965 means the car received the standard engine for that application. Optional engines coded accordingly.
    • Agree Agree x 1
