Hey guys, my fuel gauge has never worked properly, and I have decided to turn to this forum for help again as this is stumping me. First, some background information regarding the problem:
Originally, it would start to move whenever you turned the key left or right but it would stop before getting to the E mark, however if I unscrewed the gauge cluster and pulled it out a bit it would start to read "properly", though I was never able to confirm this. This sounded like a grounding issue to me, however while diagnosing it for a few days I accidently fried the gauge, so I have to rebuild it.
Pictured below is the extent of the damage caused by me frying it after I took it apart:
It charred the wire pretty bad, thankfully I had a quick reaction to it and was able to prevent an electrical fire or further damage to the gauge. Here is a picture of the rebuild I did, (I also had to replace the white wire with a copper wire because when I turned the key it blew up instantly):
I attempted fixing this the best I could, though a critical error I made was I used the wrong gauge of copper wire, (I used 24 gauge), which seems to not play nice at all and caused my temperature gauge to instantly move on start-up to about the middle before I shut off the car. Obviously, it is letting too much voltage through, which is why I need your guy's help on which gauge of wire I need and any other useful tips. I am also aware of the shoddy connections and soldering, I am pretty new to all of this, but I did test it with a multimeter and it was all connected fine. I appreciate any helpful responses and I hope this forum can help me solve this problem.
