68PK21 440.6bbl
NOT MINE!!!... Saw this awhile ago and think (even thou I'm not vert friendly) that these may be a desirable needed item, again do your own authenticity & verification checks. 24 pics only gonna do a few.
1966-1969 Dodge/Plymouth convertible top latches 1966-69 NOS
Updated on 10/4/18 with more photos. I added photos of a used set I had. The RH side is on the left, LH on the right. The RH is heavily pitted on the ribbed portion of the operating arm. The LH one has very nice ribs and chrome...but a light scratch on center piece...hard to see in the photo. Both of these are missing springs. And the RH has one of the pins backing out or missing. Both are sprung in the frame from years of tension. That's more obvious when I put the NOS in line with them (far right). The NOS piece has a square frame all around. But it does have some grazes and hits on the ribs. The middle LH piece actually has a cleaner look to the ribs but a couple deep rust pits. The $250 covers the used set and the used pair. The last 9 photos show the NOS latch and box.
Also added some photos on my NOS 1970's red/white/blue oil filters and 5/16" fuel filter 2525254/L-201 date code 0179 (Jan 17, 1969) which fits factory stock 340/383/440/440-6/426 engines. For sale as well.
______________________
NOS part #'s 2520613 / 2520615 (Left Hand side / driver's). Works for any Plymouth or Dodge B body convertible. Writing on the box says it works for 67-69 A Body as well. Also 1965 Plymouth or Dodge. Probably fits some C bodies too. I'm sure about the fit on the later B bodies. The full assembly of both LH and RH parts is called 2520611. This one LH latch assembly is $225. The used LH/RH pair for parts/repair are another $25 if the NOS latch is purchased. 3 latches total.
LH side from an NOS Chrysler set I bought in 1999 for my 1969 Plymouth Roadrunner convertible show car. I used the passenger side top assembly as that one wasn't latching correctly and was pitted. This other half of that pair never got installed before I sold the car in 2004. This is the real deal that is required for a concours, high point restoration.
Cash only. If you reply by email place "roadrunner vert" in your title. Vintage, GTX, Dart, Coronet, Coronet R/T, Satellite, Fury
post id: 6715055795
posted: 2018-10-04 4:49pm
updated: 2018-10-04 4:52pm
post id: 6715055795
