For Sale 1966 CHRYSLER NEWPORT - $7000 (SIOUX CENTER, IA)
67newport
eastern oh
not mine
1966 Chrysler Newport sedan. Original paint. Original interior. Radial tires. Runs and drives without issue. 24649 actual miles with maintenance records for proof. Original Chrysler Certicard. Color: Ivory. Interior: Blue. No known electrical issues or grounding issues. Stored inside all of its life. Small rock chips on front of hood and one by passenger rear wheel cover. Can provide more pictures or videos if desired.
Nice looking car. From the description should be almost like new. I might have to make an appointment to see it.
not mine
Jeez. . . If mileage is correct, this car was driven less than 500 miles per year. I bet there is a helluva story that goes with it.
This does look to be in very good condition but I question the odometer reading. The zeroed trip meter is a tell-tale sign that the odometer is broken. Someone reset the trip meter to zero, but since the gear is broken which drives the trip meter and odometer from the speedometer input, the trip meter is now stuck at zero forever. Common problem with these clusters. I have a big box full of them, all with the same problem. When I come across one at a swapmeet now, I'd only buy it if the trip meter does not read zero. Otherwise I assume the gear is stripped.
