NOT MINE 1966 Dodge Dodge Monaco $10,000
67newport
eastern oh
not mine
063_n.jpg?_nc_cat=104&ccb=1-3&_nc_sid=843cd7&_nc_ohc=rZFKI82i0qYAX9anFKh&_nc_ht=scontent.fagc1-2.jpg
898_n.jpg?_nc_cat=104&ccb=1-3&_nc_sid=843cd7&_nc_ohc=MKx-I5-vxSsAX9fxbRa&_nc_ht=scontent.fagc1-2.jpg
340_n.jpg?_nc_cat=108&ccb=1-3&_nc_sid=843cd7&_nc_ohc=uGuJhIQvuNkAX_Q0jSh&_nc_ht=scontent.fagc1-2.jpg
206_n.jpg?_nc_cat=100&ccb=1-3&_nc_sid=843cd7&_nc_ohc=eRpwgmW_4UoAX81KyV5&_nc_ht=scontent.fagc1-2.jpg
572_n.jpg?_nc_cat=109&ccb=1-3&_nc_sid=843cd7&_nc_ohc=7txvewJXaVQAX_6YPnp&_nc_ht=scontent.fagc1-2.jpg
603_n.jpg?_nc_cat=105&ccb=1-3&_nc_sid=843cd7&_nc_ohc=3aZ3MahrRg0AX9LbWTk&_nc_ht=scontent.fagc1-1.jpg
020_n.jpg?_nc_cat=107&ccb=1-3&_nc_sid=843cd7&_nc_ohc=pEfRs2P0Y9UAX8I02kx&_nc_ht=scontent.fagc1-2.jpg
334_n.jpg?_nc_cat=108&ccb=1-3&_nc_sid=843cd7&_nc_ohc=VDKSerxOasMAX8Pzn_8&_nc_ht=scontent.fagc1-2.jpg
382_n.jpg?_nc_cat=110&ccb=1-3&_nc_sid=843cd7&_nc_ohc=YpllPjwDvdMAX-l-y38&_nc_ht=scontent.fagc1-1.jpg
BSDszWJMcRN8qUYguiEmzGtRULLt9ZFyr_zyU6ir6ul3Fhk50NMMwzcQusMzcXpp-H2LubQF&_nc_ht=scontent.fagc1-2.jpg
792_n.jpg?_nc_cat=101&ccb=1-3&_nc_sid=843cd7&_nc_ohc=egq3NAX928kAX80MvfB&_nc_ht=scontent.fagc1-1.jpg
You are looking at a 1966 Dodge Polara Convertible. Monaco was a higher trim level. The option was not listed to pick for the add. Older restore that is showing some sign of age. Some areas that had rust repair are coming back through. Mostly in the quarter panels. Right front fender had some minor denting. Newer top. New tires. Manual drum brakes work good. Power steering leaks. Replaced the pump and the O rings on the gear box but it still losing fluid. Have a new reman. gear box that goes with the car. 383 2bbl runs good. Added electronic ignition. 727 trans shifts good but leaks from always sitting. Gas and temperature gauges not working. Bought and replaced a new temp. gauge that has the 5v step down resistor to power the gas gauge but didn't fix issue. Gas tank level switch and ground strap replaced but didn't help. Didn't run hot and always kept the tank full so I never had issues cruising in the car. Was not my daily driver. Have the shop manual and some extra parts. I'm asking $10,000 or best offer. Not interested in any trades.
