NOT MINE 1967 Dodge Polara Wagon 383 engine Chrysler Mopar - $2,000 (Independence)
67newport
eastern oh
not mine
1967 Dodge Polara Wagon 383 engine Chrysler Mopar - cars & trucks -...
1967 Dodge Polara wagon
Numbers matching all original
Original 383 engine factory 4 barrel carb (325 HP 10.0-1 compression) automatic transmission
"Clear title in hand"
This wagon has been sitting in a garage for the past 22 plus years
After determining the engine was free I changed the oil & filter, replaced the ignition points and coil, I then primed the carb and it fired up. I then ran a fuel line from the fuel pump into a gallon of gas and let it idle for about 20 minutes.
Would be a great vehicle to rebuild as is or use the drive train for that mopar you have always wanted to build.
I have not driven it on the road due to no brakes and bad tires. The transmission does go into forward and reverse. It did back into the spot where it is parked under its own power.
The rear power window still works.
The right side cargo glass was broken out years ago and the critters have been living in it since.
The keys were lost long ago so I replaced the ignition key & tumbler and yes the engine cranks as it should.
Serious buyers only, no tire kickers or dreamers.
Cash in person sale only
