Ive noticed some minor surface rust behind the bottom trim on my car behind the wheel trim and bottom trim piece beneath the door. Any ideas on how i can take the trim off to fix it? Thanks!
The wheel opening moulding is held on with screws under the edge.
I believe the rocker moulding will have screws under the bottom edge and the top edge will be held by fitting into plastic clips under the trim. Take the screws off to lift the trim away from the clips.
