1967 Imperial Convertible for sale.
Tsarofcars
Maryland
$7,500 Negotiable
STATUS: Clear MD Title, garaged and continually driven; 1 of 577 built; Grade: 4 Plus
SOURCE:
The car was sold in Beverly Hills, CA in 1967, later sold in 2000 to a dealer in LA. I bought the car in January, 2000 and am the third owner. The speedometer head has been replaced so the exact mileage is unknown but given my annual 2,000 miles or so, I estimate total mileage at about 120,000.
DESCRIPTION:
White exterior, light blue interior with black cloth tope and glass rear window. 440 ci (7.2 L), 4 bbl, automatic transmission; power steering, power brakes, power windows, power vent windows, power door locks, power top (serviceable cloth with glass rear window); AM/FM radio; power bucket seats with center “buddy” seat; heater & manual A/C, tilt/telescope steering column, no cracks in dash pad. A MOPAR© electronic distributer and ignition has been installed along with new spark plug wires and plugs. Interior seat upholstery, rear window well and carpet have been replaced. New pushrods, hydraulic lifters and rebuilt heads (Aerohead©) with 88 cc open chamber design, 2.14 x 1.81 stainless valves, 3 angled valve job, 185cc intake port volume, umbrella seals, 0.509” lift valve springs, 7 degree locks, chrome moly retainers and bronze guides. The trunk has a set of finished panels with insulation and carpeting.
MECHANICAL WORK DONE: Many replacement parts have been installed within last 10,000 miles: (1) disc brake calipers; (2) disc brake rotors; (3) carburetor; (4) radiator; (5) fan clutch; (5) alternator (6) fuel pump; (7) water pump: (8) battery; (9) battery cables; (10) rear leaf springs and shackles; (11) hoses; (12) brake pads; (13), power brake booster; (14) master cylinder; (15) valve cover gaskets; (16) side power window motors; (17) custom BF Goodrich 235 by 15 by 75 radial 3/8” ‘bluewalls”; (18) quartz clock movement; (19) transmission neutral switch; and, (20) fan belts.
STATUS: The car is a grade 4+ and needs TLC – mainly cosmetic. The reserve price is low commensurate with the current grade of the car and the amount of new, NORS and good used parts recently installed and others which go with the vehicle. (One turn signal lens alone was recently listed for $450 on eBay.) There is minor rust through below both bumper ends. Some minor surface rust but no “thru” rust is in evidence in the floor, outside rear quarter, front fenders or rocker panels.
MANY EXTRA PARTS INCLUDED: (refer to pictures): cornering lights and extra lenses, hoses and belts, AM/FM radio, trunk lock and keyset, roof rail weather stripping, radio bezel, tail light assemblies, two heater / AC dash control head, chrome trim, repainted bumper jack stand, base and lug wrench, two speedometer heads with gauges, dash switches, power antenna, walnut veneer sheets, dashpad and more (See photos).
WORK NEEDED: (1) repaint; (2) bumpers re-chromed; (3) vent windows are slow; (4) recharge A/C; (5) replace heater/AC control head – two used units go with car. Being a 50-year old car, it is being sold AS-IS, WHERE-IS with NO WARRANTY expressed, written or implied. Seller assumes no responsibility for any repairs.
Looks like a decent driver, best of luck finding a new home for it.:thumbsup:
This is exactly what I'm looking for. Would you be open to trade for my 70 charger RT mint 6 pack car? Its white with blue interior as well. Its currently on eBay and also hmn. No. Not straight across.
I'm in BC Canada
Nice car. However, I have a couple of other things I would add under "work needed"
1) Door panels...because they were chopped up with an amateurish speaker install;
2) Buick wheel covers- throw them as far as possible away from the car.
Pretty sure I have the parts to fix the door panels.
