1967 Plymouth Fury III
BlueVenger22
Tennessee
Hello, I have a 67 Fury that I have been tinkering with and am thinking of selling. It had been sitting for a few years when I got it a few months ago. It has the 383 big block 2bbl engine, 727 torque flight trans. Factory front and rear a/c car. Doesn't blow cold. Haven't really investigated. There is an exhaust leak at the passenger side manifold and the speedo is stuck at 120 but the odometer still works. There is a little spot of rust in the driver's rear quarter panel and driver's side rear window under the moulding but not bad. New parts include tires, fuel tank, sending unit, fuel pump, carb, battery, pertronix ignition, axle bearings and oil change. It has a little miss but I have yet to change plugs, wires, cap and button so that is more than likely it. I haven't had that much time to look in to it yet but it still runs good. You can drive it home without worries. I lowered it with the torsion bars up front and speedway motors aluminum lowering blocks in the rear. It's nice and low but doesn't bottom out or scrape everywhere so easily driven around without concern for dodging bumps and potholes. Can easily be raised back up. Just realized the other day that the heater core is bad. It doesn't leak but blows steam on the windshield if you run the heat. I didn't know about this until it got colder and I drove her the other day. I had it listed for 4200 before realizing this problem with the heater core. I just don't have the time to repair or replace it. This is the only real issue but car still runs and drives fine just no heat. Price is negotiable. May intertain trades just let me know what you have. Call or text me any time. Text is preferred but calling works as well. I have a strange schedule though so if no answer just leave me a message and I will get back with you as soon as I can. Thank you, James. (423) 605-3095
