Bigasawhale2
- Joined
- Jan 25, 2014
- Messages
- 55
- Reaction score
- 51
Hello,
I am trying to figure out 1968 Newport Auto Pilot Servo - system
The FSM – shows the Imperial system in accerrories section, and in the electrical section shows what must have been used in Newport's.
The next best reference I have is a 1969 B Body set up – which outlines the 2 vacuum line servo system in following picture. This is the picture of servo in '69 manual – has 2 Vacuum ports on the same side:
The unit I bought as NOS –many years ago…Has vacuum ports on 2 sides, but on different sides.
Hopefully the pictures attached ok
Does anybody recognize it - the second servo ?
Testing units servos:
Vacuum load from engine held at a constant level, with the brake port closed, open the brake port – vacuum should go to atmosphere
Is this the right way to go about it ?
Thanks
Thanks
