WANTED 1968 Fury speedo
Kiwirover
Auckland, New Zealand
Hi all. It seems that the speedo on my '68 Fury is knackered and in the process of trying to fix it I managed to break one of the studs off the back of the temp gauge... Does anyone have a complete cluster? Or just the speedo? It's a Fury 3 with column shift auto but i'm pretty sure they're all basically the same for '67 and '68. Cheers.
I have a 67 for a manual trans you could use for parts
Sounds promising. Is it in working order? Does the manual one have the little window for the gear selector in the bottom of the speedo?
Looks like there’s two more choices for you that are closer so those are your best options.
