68PK21 440.6bbl
NOT MINE!!!... I don't know what to say about this one, steering wheel?
Oh and... Double HOSE ALERT!
1968 Plymouth Sport Fury 440
title status: clean
Letting go of my 68 Plymouth Fury in Clayton since I'm not currently able to find blocks of time to do the work needed to get her drivable. I'll list all the known good and bad here, the bad sounds like a lot, but it's a bunch of relatively minor fixes I just don't have time for.
Good:
-Decent body
-Excellent interior
-Runs well when started (been about a month since last started)
-Solid frame, some rust since OH car
-Rear drums replaced with discs
-New fuel pump
-New master cylinder
-New front wheel cylinders
-Clean title
-Really solid project car
The Bad:
-A bit of surface rust, with deeper rust around the back windshield
-Needs new paint, flaking off in spots
-Brakes need new lines between master cylinder and distribution block
-Needs new starter solenoid relay
-Parasitic battery drain somewhere, assuming where previous owner pulled out aftermarket speakers or behind their aftermarket stereo
Some ghetto rigged headlight switches and tachometer I haven't gotten around to replacing due to bigger issues I'd been prioritizing.
I think that's all I have found with the car. For $3500 it is extremely solid, and with some cheap parts and time she will easily be worth significantly more, I just don't have that time.
Call or text any time at Nine Three Seven 441 (see ad)
post id: 6598151003 posted: 2018-05-24 4:02pm updated: 2018-05-24 4:03pm
title status: clean
Good:
-Decent body
-Excellent interior
-New fuel pump
-Clean title
The Bad:
