1969 Fury radio interchanges
66l78rat
troy mi
Will a 1972 c body radio 3501 521 fit in my 1969 Fury without modification to dash panel.My car has working am radio but would like to get fm stations for cruising.The 72 am/fm has knobs instead of thumbwheel but I don't care if it fits n looks like it came from factory.
actually you can---i just fit a pioneer radio into my 69 fury-----the thumb wheel was scratchy and unfulfilling-----first take off the radio side of dash faceplate----drop your AC tube from beneath the steering column---drop the radio out the backside---now take the pioneer radio and carefully slide it into the loose faceplate-----it is a perfect fit--take it back out---replace your empty radio faceplate----look into the abyss and you will see the metal frame backing interferes 1/4 inch on the left and 1/4 inch at the lower left corner-----scribe a mark----take the face plate back out-----get out the angle grinder----next fire control---sprayed water under neath dash--just moist--then hung a shop rag behind the hole to be cut----didnt want to burn down the fury------carefully cut out an L shaped piece of metal-----the metal frame will still accept the original radio---it isnt ruined forever----put the dash plate back in place loose---carefully slide the pioneer into place--replace screws and AC duct--make a strap to brace the back of radio-----you are done...,.
Which model number Pioneer unit? What about speakers and related placement?s
Thanks,
it was just one of those cheap slide into a collar type pioneer super tuner IIID----also avoid the radio with the pop off face plate---if you accidentally pop it off the radio will fall into the dash-----for now i just put speakers in the rear package tray from the bottom side (trunk)---there are precut holes with screw holes (6X9)--and the insulation under package tray is precut and will fall out----one side was already part way out and i had to pick a little at the other side to drop it---you dont need the speakers grills--they interfere with screwing the speakers in from the bottom...make sure to pick the correct length of screw---you dont want it poking up through the package tray material...
