WANTED 1969 upper column bearing (housing assembly) - chrysler 300
gransedan
NL
looking for 69 upper column bearing (housing assembly) - chrysler
I re-greased it but there is still play in it.
Mopar # 569 8362
GM # 5698375 (67 68 gto chevell nova cutlass camaro)
Anyone have something available?
And any information on the lower bearing? Which part number (s)?
I can provide a shipping label if somebody has something available.
I consider a good used one if nice and tight.
Looking forward to the reply's.
Thank you in advance.
Pieter
It need to fit into this upper steering column housing assembly.
There is no rubber there....
From what I have read this is 68/69 only.
Maybe it's sold only as an assembly and not a separate bearing.
I have a parts column from a ‘69 300, I’ll dig it out and let you know if the parts are good.
The upper does have a slight bit of play but hard to tell if that is normal being off the shaft. How much play is good, I do not know. The other one, I believe the lower, is firm with a good rubber bushing.
