For Sale 1970-1973 tilt column and wheel.
Cop car wagon
Everett
You can make it a value pack.
A column with a wheel, and a spare wheel.
It will definitely need a clean and overhaul. It got caught in the paint booth once and had some overspray fog.
The telescopic function is good and tight, no lever to test tilt.
Has a turn signal switch with wires cut, but it operates well. Cruise wire is broken, but stalk chrome is decent. Has ingition switch rod. Column sleeve may need the collapse mesh straightened.
Gold wheel has one crack, plus normal cracks on back like the green one.
Green one is better, one chip but I have the missing chip to glue in.
Cover was green, painted gold.
Both wheels need horn strip. And sanding, polishing. At least you can sand and polish, no texture to remove.
I'm sure there might be questions.
Column , gold wheel, and cover, $125
Green wheel with black plymouth center. $50
Plymouth center cannot be common.
Plus shipping
