The Low Beams are on the outside. On Furys, Galaxies and Pontiacs with vertical headlights, the Low Beams go to the top.
On vehicles with four headlights, like our C-Bodies and most other full-size cars of that era, you could end up with a situation where the Halogen Sealed Beam replacements will be pulling too much current for the car's wiring and switches.
If you compare the original non-Halogen Sealed Beams to the Halogen replacement Sealed Beams, you'll notice that the total wattage on High beam is higher with the Halogens.
-With the original incandescent headlights, you had two 60 Watt Low beam lights for a total of 120 Watts.
-With the Halogen replacement Sealed Beams you have two 35 Watt Low Beam lights for a total of 70 Watts. So, on Low Beam, the wattage is actually lower with the Halogens.
The difference is in the High beam filaments. With the original incandescent Sealed Beams, there were four 37.5 Watt lights for a total wattage of 150 Watts on High Beam, but with Halogen Sealed Beams, there are two 35 Watt filaments and two 50 Watt filaments lit at the same time, for a total wattage of 170 Watts on High Beam. All four Halogen High Beam lamps are not the same wattage. The inside pair are higher, brighter.
It's only 20 Watts more, but it can cause the headlight switch to fail. That's what it did in my case and it also melted the connector at the dimmer switch on the floor. My solution was to make a Headlight Relay harness. The relays take the load off the headlight switch and the dimmer switch, so, the switches should last a lot longer.
I hope this helps.
