1970 Chrysler 300 - Wiring
Fuselage Years
  1. Waggy
    Waggy Member
    74
    3
    Sep 10, 2014
    Surrey BC
    I have removed all the old wiring and replaced it with a PainFull Wiring Harness. The harness is OK as far as it goes, but the section about Mopar is useless! There is nothing on the dash. I was hoping someone could tell me how to set up the charging gauge. They have nothing on warning light gauges. The old harness, seems to have #10 wire going through it and as I am replacing the wiring because I was losing the total power to my car, I would like to have the gauge work, but also a #10 wire by-passing it. Is there a problem just connecting it in parallel? Painless could not supply me with a wiring diagram for their Mopar harness, so I am thinking of having a #10 wire from the Charging gauge to a new fuse box and if I need power, run fresh wires from there. I know I need power for the windows, roof, and the headlight doors to start.
  2. Ripinator
    Ripinator Senior Member
    3,146
    1,396
    Jul 31, 2013
    Germantown, MD
    Here ya go. . . Order the big one:
    1970 Chrysler Color Wiring Diagram
  3. FURYGT
    FURYGT Senior Member
    1,115
    407
    Mar 11, 2017
    Middletown, CT
    The following MOPARTS thread and the link within this thread may be helpful. If you are re-wiring the car, you should consider bypassing the amp gauge and you may also want to search for how to wire a head lamp relay set up. You may even find this by searching within this site.
    Amp meter by-pass | Best of Moparts / Tech Archive | Moparts Forums
