NOT MINE 1970 Chrysler New Yorker Coupe - $7,500 - Jurupa Valley, California
T-revorNobody
Sidewinder, Colorado
At time of posting, the listing is 6 hours old.
FB Description
1970 Chrysler New yorker, 440 ci big block 727 Automatic. I pulled the motor out and put all New gaskets and had the transmission rebuilt.Motor work New gaskets including Valley panHead gaskets Oil pan New double roller timing chainTiming chain coverValve cover gasketsExhaust gasketsWater pump gasketsFront suspension work New rebuilt steering boxNew inner and outer tie rodsNew pitman New idler arm Greased all New and old suspension parts including u-jointsBrake work New brake pads front and back New rubber brake hosesNew master cylinder New brake boosterThis vehicle has been gone through front to back everything mechanical, it has greate patina , I have many many extra parts ( interior and trim ) that would come with the car at full price ,the interior could use a overhaul, it cruises down the freeway at 70 no problem and gets a lot of thumbs up from on lookers.
I can't say I've ever seen this colour on a fuselage before. Looks like coral turquoise metallic? I think it's my new favourite!
This seems like a pretty good deal given the amount of work he's put into it.
I think the color is P6 Teal. Standard bench seat, crank windows, drum brakes. The only options seem to be the tilt&tele steering wheel, and AC. It used to be a nice car. Needs a lot of work now, though. - It is the 25th in my list of 1970 NYer 2d HTs that survived.
I wonder what brakes it does have?
Seller's diahrrea description says new pads (which suggests discs) but then says front and rear.
Brake pedal bezel does not say disc brakes.
Has a drum-brake master cylinder (new), but on a disc-brake booster (also new).
Whenever I see one of those $3 plastic may-crack fuel filters it makes me question everything else.
