NOT MINE 1970 Chrysler Newport Convertible (383-2, Denver, 87k miles, $13.5k, two-tone gold)
ayilar
USA
This Newport 'vert has been available for two weeks in Denver, CO on CL and FB. The ask is $13.5k. CE27L0C157328 looks nice. She has been repainted in a different color than the original FY6 Citron gold below the side mouldings. Lots of documentation.
The ad seems like it provides an unvarnished description of the car:
"This is a car I acquired last year and have done A Lot of work on. Including New Heater/AC core. New power brake Booster, N.O.S. Carburetor 383 2bbl, Brakes All around. New Fuel tank and sending unit. I wanted to get it back on the road. The previous owner of 13 years rarely drove it. It only has 87K miles. When I got it, the rear quarters were in primer. So, since I knew just painting the quarters would not match at all, I had the Entire lower half painted as a 2 tone. Not a show paint job by any means. And the paint is faded. All the trim is there. The Convertible top is ok, but could use replaced. The AC and radio do not work and the rear driver-side window can be finicky at times. The car runs good. Power Convertible top works good. I'd give the car a 6 out of 10. Far from perfect, but a great old Mopar convertible. (...) I replaced the Entire rear Bumper assembly with a 71' Chrysler 300 assembly. Looks cool. I kept Everything from the factory Newport assembly if you wanted to switch it back, Nothing was cut or altefred on the body.
I have reams of paper-work from the previous owner in a folder. Have the build sheet as well. There was no spare tire when I got it, but have the Entire jack assembly. I can locate a spare tire if that's a big deal. Just hadn't put time towards that.
fury fan
Indianapolis
Decent car, presentable, but price seems high for the cosmetic work it needs.
And the color mismatch in the seatcovers, front and rear, seems really odd.
ayilar
USA
This may be a lighting artifact. The different plastics in the 1970 gold vinyl interior seems to age differently, leading to some color variation -- something that artificial lighting emphasizes.
marko
Victoria, BC Canada
the driver's side seat bottom has clearly been been replaced, it would be pretty hard to match the stitching and padding look.
ayilar
USA
SMS has the correct material, and the stitching can be matched by the right upholsterer. Been there, done that. But in this case, indeed, neither the material color (subject to my earlier caveat) nor the pattern seems correct.
PS: I have just posted this car's broadcast sheet in the Last of the Convertibles registry.
chry73luv
Agreed. I have a 73 Newport with a white interior and even after keeping it inside for over 23 years it is amazing how different plastic parts have yellowed. Even with no sun hitting it. It happens over time.
chry73luv
This looks like a very solid starting point for a convertible. Alot of work was done by current owner.
fury fan
Indianapolis
And that's what I meant, the material sheen, pattern, etc suggests that someone has selectively repaired sections of the seats with 'close' material.
It would seem such a repair, even if you can't afford the factory-correct upholstery, at least getting the seats to match each other in the 'close' material and sewing style would be better than a botch-job. Especially when the surrounding material/stitching is suspect to degrade afterward. And there appears to be a seam-pop in the upper part of the driver's seat, perhaps an example of what happens to the surrounding original material.
