NOT MINE 1970 Imperial 2 Door - Listed as New Yorker - $4,700 - Northern California
aaron72
Martinez, CA
Listed as a New Yorker but appears to be an Imperial.
From the ad:
Clean title, current tag
Runs, drives and stops good
440 big block engine
Needs paint and interior work
$4700 obo
Located in Pleasanton, CA
1970 Chrysler New Yorker for sale by owner - Pleasanton, CA - craigslist
Saw this earlier and went no it is an Imperial. Only 24 miles away. Unfortunately the interior will cost thousands so I'll pass on it.
Cheapest 2 dr fuselage imperial I’ve seen in a while! If this was in the Midwest it would be on its way to my garage already!
Looks normal for a outside California sunshine car paint and seats are already baked But no rust work to repair and would be costly to do right
The Imperials have smaller rear formal window than the New Yorker. The two cars share the same roof, so a plug/insert was developed to create a formal roof with smaller window. Cheaper than stamping a complete new roof for low volume car.
This particular car has some rust under the rear window plug , would you be able to cut a panel from a New Yorker as well as a imperial for a patch?
So, how is it?, drives good?, any rust besides the window plug?
ill make a separate post about it when i have it in hand. Window plug need a patch one small issue in trunk pan, but its all there and drives well.
