1970 Imperial LeBaron coupe, vinyl top padding
Olaf Roed
Berkeley Lake, GA
I am replacing the vinyl top on my 1970 Imperial LeBaron coupe. Going with the black Levant grain vinyl top as it originally came with. Did these vinyl tops use a padding under the entire top, or just on the sides and/or around the back glass plug area? And how thick should the padding be? (I cannot use the current top as a reference as I suspect that it may have been replaced before. It has a relatively thin white padding under the entire top).
Also does anyone know of a good supplier of trim clips, both for the vinyl top moldings as well as for the upper and lower body trim? Thanks.
Was that additional padding over the rear window plug area there for visual effect or to better cover-up the presence of the plug itself?
As most of the currently-available vinyl top fabrics are thinner (in total build thickness and in the vinyl depth itself), you might need to find some polyester padding to add to that area?
Just curious,
3C's & a D?
By the tree in Edmonton
Just curious,
I would wager it was done in the name of efficiency. The insert has several deep screw holes used to connect the inside to the outside, along with the entire gap around the insert. With different expansion properties between the plastic or fiberglass insert, and the steel body, filler would likely crack over time.
thethee
Netherlands
I'm around 80 percent sure that the vinyl top I removed from my 75 Imperial was the original. I know, different year, but it does have the rear window plug with the deep screw holes. The vinyl seemed to have the same padding overall but all around the rear window was a white plastic strip to cover the plug. I'd say 3-4 inches wide and maybe 1/16 inch thick.
