1970 Plymouth wagon - WA
Homerr
Seattle
$2650
Different front and rear plates.
1970 plymouth wagon-383 engine with fresh valve grind, Runs great
-new exhaust system
-new plugs, pintes,cap, rotor, and pug wires
-interior good, sagging headliner
-michelin tires lots of tread
-running gear in good shape
-adjustable overload shocks
-been in barn more than ten years
-some rust
-long wheel base
-rear glass still intact, window goes up and down
-5th door works as tailgate or door
This wagon has been sitting in a barn waiting to be discovered call today to find out more.
http://seattle.craigslist.org/tac/cto/4563827606.html
00v0v_bnV91PAUK5A_600x450.jpg00i0i_isNejBQ5LxM_600x450.jpg00U0U_545D5cx5afx_600x450.jpg00c0c_2ML6DPi5ePQ_600x450.jpg
Looks like it, the collector car plates have text to the left of the numbers iirc.
Wagons are going to be the next big $$$ C-Bodies.
rear plate looks like a collector issued plate...if you have that, you can run any plate on the front you want...even no plate up front
OMG....that turn key one is beautiful!
Looks like GG-1 Cypress Green Metallic.
We'll see how this turns out.
You could not buy and restore that car for the asking price ...... not even close.
The bondo doesn't scare you?
Bondo is not your enemy .......... If properly used and applied it works great.
Filling rust holes with newspaper and fiberglass and then covering with bondo is what gives it a bad rap.
