1970 Sport Fury...woodgrain on dash and door panels
Fuselage Years
  1. Cadee
    Cadee New Member
    37
    14
    Sep 17, 2017
    Ontario, Canada
    I'm looking to replace the worn out wood grain on the dash and on each door panel on a 70 Sport Fury.
    Does anyone know if it is exactly reproduced or... where I could get a close match?
    Thanks.
  2. LeBaron1973
    LeBaron1973 Old Man with a Hat FCBO Gold Member
    5,573
    800
    Sep 13, 2015
    Harewood, Christchurch, Canterbury, NZ
    I should think the woodgrain material used is 3M di-noc vinyl as that was used on the outside of the "woodie" cars and wagons back then.
    Hopefully something similar is still available if the "exact" pattern has been discontinued.
    Good luck with your search.
  3. Davea Lux
    7,987
    1965
    Mar 27, 2017
    Cornelius Or
    3M still makes the product line, do not know if the exact material is still available. If you google 3M DI-NOC, some links come up about the product.
  4. Fury Pursuit
    Fury Pursuit Senior Member
    1,635
    1957
    Jun 28, 2014
    I reproduced it to exact specs.
    How much do you need?
    • Like Like x 4
  5. Cadee
    Cadee New Member
    37
    14
    Sep 17, 2017
    Ontario, Canada
    Fury Pursuit, i need the four pieces that go on the door, one on each door.
    each piece is 13 1/2" long by 2 1/2" wide.
    I also need the long strip that goes along the passenger side of the dash. It is 32' long by 1 1/2" wide.
    I have added some pictures. Thank you sfgt wood grain trim 2.jpg sfgt wood grain trim 2.jpg SFGT WOOD GRAIN TRIM 3.jpg
  6. Beep Beep Dave
    Beep Beep Dave Senior Member
    1,088
    713
    Feb 15, 2013
    Brantford Ontario
    Good to know.
    • Agree Agree x 1
