1971 Disc caliper pads - Recommend??
Commandough
Rossville, KS
Before I go back to NAPA or before I order from Rock Auto, can anyone recommend a set of disc brake pads that fit? The ones I got do not line up right with the side opposite the piston (a touch too narrow) on my pin caliper. Rock Auto has some Raybestos that look wider but I can't be sure. Whole set up from a 71 Fury with 1.25 thick rotors. What have you guys had luck with?
I think I had the same problem once. Are you referring to the space between the ears on the pads not being able to slide up onto the caliper? If so a quick trip to the bench grinder should do the trick, a file would even do the job.
The same. I'm working out of an 1890 Ice House without power or lights so work gets done only when it's inconvenient!! I can always hand file it, just thought I might be better off finding a pad that fits.
Haven't heard from you -- have you got massive snow banks out there in Kansas and no snow shoes??
