For Sale 1971 Imperial $4,000
ma_mopar
Runs and drives. New timing chain/gears, water pump, alternator in 2017. Tires were new in 2017 as well.
Just over 102K miles. Windows do not roll down. Not exactly sure why. Worked before. If I get them working again I'll update.
Asking $4,000 to any member on here. Car is the Kansas City area. Clear and clean title.
ayilar
USA
@ma_mopar : thank you for listing CM43T1C134554 for sale here. Very nice color combo and the interior looks good from the little we can see. It’d help if you could show the interior in detail, the underside, and the trunk pan.
ma_mopar
I have some on my computer. Will upload them when I get home.
ma_mopar
Other interior photos. These are from around the time when we got the car. Interior basically looks the same except some more dirt in the current photos.
Xenon
Over Yonder
What is that thingy the speedo cable is attached to
and where does the wire off of it go..? What does it do..?
Where is the suppose to plug into..?
ma_mopar
The wire I am unsure of what it's exact purpose is.
The other thing leads to the cruise control if you follow the hose the other way. The wire appears to be attached to the cruise unit on the trans. The wire is broken/cut and the other end goes to another part of the transmission that I can not reach or see from crawling underneath.
78Brougham
"Chump"
Wellsboro, PA
That's the speedometer cable. Runs from the trans, to the cruise control servo, then there should be another one from the servo to the speedometer.
Can't tell what that wire is from that angle...
