1971 Jensen Interceptor 383
Turboomni
MA
9000 bucks with a 383. I think some had a 440.
https://barnfinds.com/potential-bar...tm_medium=email&utm_source=Newsletter+(Daily)
Me to MarPar and too bad it's an auto trans, interesting car though I think.
I thought most, if not all had a 440.
No, they originally came with 383... Later came with 440..
In later years there was even a convertible..
The one pictured is exactly like the one I had with exception to mine had an all black interior....
Great driving car but anything electric was a major suck... Lucas electronics.. Cable drive wipers..
The footwell where pedals are also rather tight....
This is just for fun, I failed to save the pictures, from a 2004 eBay auction:
Vehicle Description
Jensen built over 6000 Interceptors. continually, developing and debugging the model for nearly ten years until it almost wasn't horrible. Alas, this is an extremely early example, so it's horrible in every conceivable way.
Granted, as the 180th Interceptor ever made, this right hand drive '67 Type 1 could be worse. The first few dozen of these overheating, pig handling, self immolating rustbuckets came with Vignale built bodies of such staggeringly poor quality that the ENGLISH wouldn't accept them, which is saying quite a mouthful. Even as it is, this British built version was apparently made from an alloy of salt, wet newspapers, and tuna cans. The front floors, both sills, most of the exterior front bodywork, and the left doorpost are all shot; the inner front fenders and box sections have taken a similar stroll across the periodic table, as have the lower parts of all four outer fenders. The hood, while fairly free of corrosion, appears to have been run over by a monster truck.
On the upside, the greenhouse and rear clip aren't too bad. The rear suspension points are nice and solid, and the twin sewer pipetube frame miraculously escaping the usual rust ahead of the firewall that causes the entire front half of these cars to break off and roll away on their own Is totally sound. I can only chalk this up to a liberal coating of Limey lubricants having leaked from the sump and gearbox.
The engine (a Jensen spec Chrysler 383), transmission (727 Torque Flite), brakes, and radiator were all supposedly rebuilt by the car's last owner. I half heartedly buy it regarding the brakes and radiator, which look pretty new. As to the engine, I think he's defined "rebuild" as "a new can of Ford blue engine paint."
This fine example of how Britain lost its empire comes with good glass all around, working window motors, good (rare Type 1) dash and console metal, the pathetic remains of four original Armstrong Selectaride shocks, and a fairly cursory paper trail.
Vehicle Condition
Pretty sorry ***. But go ahead and email me with any questions, as I love to be reminded of that.
Terms of Sale
For starters, you can get it out of my driveway.
I always kind of liked them. Seattle and Washington state seems to have many rust free cars. Kind of a combination of my 300 and my Lucas infected MGB. :)
Actually I can't complain about my MG and its Lucas electronics, it has been a very dependable car, for over 36 years
I've had the opportunity to restore two sets of the valve covers and wooooo boy they're a challenge. The sloped design is really cool overall but they're low grade aluminum with lots of casting issues. If I remember right each has 12 different planes so a lot of the clean up has to be done by hand versus machine. They turn out sweet though.
I had a set of Jensen covers for my 66 Dodge Coronet with a 273 engine.:rolleyes:
I picked up a set of these valvecovers off ebay years ago. I think they're one of the sharpest looking B/RB valvecovers. I removed the powdercoat with methylene chloride and discovered, just as you found, the casting was pretty poor. Very rough surface and they were only finished with a grinder before powdercoating.
I don't have machining equipment, and they needed a lot of sanding to get the outer surfaces smooth. I planned to polish them smooth and I got pretty far along but that project got side-tracked when I discovered that the drivers side one hit my brake booster (1973 disc booster), so they won't fit on my Windsor until I swap-in a year-correct booster.
I remember reading this years ago as well. Good stuff, unless it has happened to you.
