1970FuryConv
I took the turn signal switch apart today
· Upper Half: Little cross bars seem a bit sunken. I'm not sure. See pics below. Both of them contact the 4 brass contacts, 2 at a time, depending on which direction turning car. I believe white wire is power from brake switch and red is input power for turn signals.
· Main concern: white brake light input wire has turned brown at hazard switch. It is wire below pink wire in 4th pic. It has to be heating up for some reason. Output is still white. 60 K ohms resistance between them. Resistance from white wire contact above hazard to top of upper half is .3 ohms
