1972 Fury Wagon Car Cover- any suggestions?
Mopar Wagons
  1. f1967franche
    f1967franche New Member
    10
    3
    Sep 10, 2015
    Baltimore
    So I have a 1972 Plymouth Fury wagon that I am having shipped from out west to Maryland. I do not have garage space at the present time ( got a 67 Dart and 70 Pontiac wagon in works)so am going to store the car on my concrete parking pad but given we get rain/snow, etc. out here on the East coast- I was wondering if anyone has any suggestions for the best/ideal cover that is weather resistant yet breathable so the car is protected but does not rot underneath. Thanks for any feedback. I do appreciate it. Frank-
  2. CBODY67
    CBODY67 Senior Member
    3,746
    846
    Mar 27, 2011
    Consider, that any dust which might be on the car when the cover is installed can become "grit" when under the cover, if it's not "absorbed" into the soft underside of the cover. With time, "sane paper"? NOT to forget about the mere size and weight of such a quality cover, plus the requisite antenna hole. Even if it was for a sedan, it would be easier if two people installed it. Moreso with a wagon, I suspect.
    Several dynamics to consider, other than getting the highest quality cover you can get for it. All will be breathable, but NOT waterproof!
  3. cbarge
    cbarge Senior Member FCBO Gold Member
    1,965
    2409
    Nov 22, 2010
    Kingston Ontario Eh?
    Other than the car cover...Buy a cheap green tarp and park the car on it.
    Works as a vapor barrier and keep the car from absorbing any moisture from underneath.
    make sure air can circulate under the car. jack it up of you have to,butt that is an option.
    Hope this helps.
    • Agree Agree x 2
  4. CBODY67
    3,746
    846
    Mar 27, 2011
    I was kind of thinking about some of the "drive-into bubble" deal for vehicle storage, which the tarp might cover, but not sure how it would stay inflated over time.
    If you park the car on the tarp, but still allow for air circulation under the car, how to keep moisture from collecting on the tarp under the car? Or do you just use the tires to anchor it to the pad underneath, as the tarp is laid over the car? Just curious.
  5. BIGBARNEYCARS
    BIGBARNEYCARS Senior Member FCBO Gold Member
    3,557
    2229
    Dec 10, 2012
    SHADOW OF MOTHER'S PROVING GROUNDZ
    Give me a day or three to come up with his 800 work# and I'll get back with you f1967. Friend of mine in SoCal is a Factory Rep for a very large Manufacturer of Car Covers in I kinda remember in Oklahoma? several 1000 patern coverz in inventory. When I give you his # call him and tell him just what you're trying to accomplish and He'll quote you a delivered price to your zip. Stand By, Jer
  6. cbarge
    1,965
    2409
    Nov 22, 2010
    I used the tires as anchors.Sometimes a few small bricks to keep the corners and sides from curling up.
    Before laying down the tarp and parking the car onto the tarp, to create a slope, lay down some wood in the middle
    Not a mountain but still have plenty of ground clearance--common sense should kick in for sure.
    Not necessary but every little bit helps.
    The car itself being almost 20 feet long shelters the tarp from moisture away directly below it...
  7. CBODY67
    3,746
    846
    Mar 27, 2011
    i'll concur that a vapor barrier under the vehicle is important, but down here, we have a bit too much "blowing rain" to keep things dry underneath anything not parked in an enclosure. Even then, without a vapor barrier under the slab, moisture can still rise and fall with temperature swings in the building.
    As for bricks, I'd put some 2x12s on the sides and then anchor them with bricks/concrete blocks for best results. Even so, some small critters might get under there!
    Many variations/orientations depending upon locale and resources.
    • Agree Agree x 1
  8. FURYGT
    FURYGT Senior Member
    2,337
    975
    Mar 11, 2017
    Middletown, CT
    I agree with putting down a plastic tarp to keep moisture from coming up through the concrete pad.
    I would also buy an All Weather Custom Car Cover from California Car Cover. Use the link below then select the "Outdoor" button.
    Choose a Cover
    The above link should bring you to the outdoor car cover options for a '72 Chrysler Town & Country Wagon, which has the same size dimensions as your Fury Wagon. I have used either their Noah or Stormweave models. You need a car cover that is going to breath and not trap moisture under it like a plastic tarp will. Their car covers are not cheap but they are high quality. The better option would be to rent a weather tight garage for the winter.
    • Like Like x 1
  9. CBODY67
    3,746
    846
    Mar 27, 2011
    That would be the best option, completely.
  10. 1978 NYB
    1978 NYB Warfighter FCBO Gold Member
    41,557
    12409
    Apr 16, 2011
    Classified
    Ironshield by
    www.carscovers.com
    I live in Maryland and it handles all weather. I have a security cable around the center and a 1" strap around the front and back and it keeps the car protected from hurricanes and blizzards.
    • Like Like x 1
  11. FURYGT
    2,337
    975
    Mar 11, 2017
    Middletown, CT
    Looks like they changed the name for Ironshield to either Platinum Shield or Ultimate Shield.
  12. GOLDMYN
    GOLDMYN Active Member
    474
    441
    Nov 23, 2013
    Kenosha, Wi
    • Like Like x 1
  13. Greg Mahley
    Greg Mahley Member FCBO Gold Member
    51
    26
    Feb 18, 2018
    West Deptford NJ
    California Car Cover Co. I believe their cover that would be best for you is the "Stormweave". I agree with putting a tarp down under the car and driving onto it.
  14. MBar
    MBar Active Member
    241
    112
    Sep 17, 2018
    Orange County California
    Hi....I picked up a 72 Fury wagon a couple of weeks ago and saw there was another locally for sale here in California...just curious if that was the one I saw... got pics?
  15. f1967franche
    10
    3
    Sep 10, 2015
    Baltimore
    Nice. Thanks so much for the feedback everyone.
    Yea- I'd keep it in my garage but I already have a 67 Dart and 70 Pontiac Catalina wagon and so until I put pavers or concrete under a side overhang on my garage - the cover is my best bet.
    I actually just found a mid 70's Buick Station Wagon. Not sure the mode- maybe a Century but looks like Kojaks car in wagon form and minus the Gold but it would be a cool wagon. I'm addicted can you tell?
  16. f1967franche
    10
    3
    Sep 10, 2015
    Baltimore
    Thanks for your feedback :)
