For Sale 1972 imperial, New yorker rear seat
sixpakbee
Nice white rear seat for a C body .I'm not 100% sure if it's from a imperial or new yorker. I know there are experts on here that can tell just by looking at the pics.so any info is much appreciated. It Has 2 build sheets still in it and it says 1972 and 1973 on the top of one of the sheets.please look at the pics to determine if this is the correct seat yout need. Located in Sabina ohio 45169.
$ 400.00 obo
1972-1973 NYer Brougham 2dr. I see T3C in the build sheet, so 1973. The medallion is red, which seals the deal (yellow in 1972).
Can you pls post a higher resolution photo of the build sheet? I am guessing CS23T3C241xxx but the text is hard to see.
Yes I'll get some pics today. Are you interested in it. Thanks
Thank you!
No, I don’t need the seat. I have a 1972 NYB 2dr and a 1973 NYB 4dr but they have black interiors. I was trying to help you with the date and make.
@cuda hunter may be interested in buying the build sheet as he collects them. Not sure that yours can be extracted safely, but that might help you maximize your return.
I would be interested in the sheets, or sheet.
First, Perhaps pull out on that spring that is covering the vin on the center of the top of the broadcast sheet and take a picture. Then we can get a vin and determine exactly what car these seats are from.
Do the two broadcast sheets match? The vins?
The sheets that are behind the webbing are very difficult to remove and impossible to remove without cutting the netting.
Ok ill check them and send you some picks.just give me a day or so to get to the shop. Thanks
Thank you!
Thanks
