Jon O.
Howdy all,
I finally had a nice enough day to jack my 72 newport off the ground and peek around at steering components. For those of you that don't know, the problem is wandering at high speeds.
After jacking up, I wiggled both front tires at 6 and 12 o'clock and 3 and 9. No play whatsoever (tie rod ends/ball joints). Crawling under the car and having someone push the tires in both directions, I noticed that the tie rod was able to move around 1/2 inch in either direction. The problem seemed to originate at the steering gear. Everything else seemed tight. Does a worn steering gear sound right to any of you? Any suggestions on what to look for?
