Wollfen
I have a 72 steel crank 440 here that has no accessories. It is a standard bore engine with a standard crank that has not been ground and the crank could be linished and used as is. It does come with a water pump and heads as well as an inlet manifold. The heads are bare but come with the valves and most of the valve springs, I think i lost two. There is no camshaft or timing gear but there is an oil pump. Now the issue with the block, there is a small crack on one side of the rear camshaft welsh plug below the hex head plug. Im sure it could be brazed or welded to fix it. I am asking 350 for the engine as i think the parts alone would be worth that. Oh and there is a second set of bare heads too.
