WANTED 1973 C Body Disc Brake Spindles Or Later
Mopar Parts Wanted
  1. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    Contact Seller
    I'm looking for 70 - 73 disc brake spindles. Doesn't matter what car they are from as long as it's a C body. I think 70 - 73 11 3/4" pin caliper bracket holes should all be the same.
    Just send me a PM.... Thanks
  2. Ripinator
    Ripinator Senior Member
    Rating - 100%
    5   0   0
    4,728
    2641
    Jul 31, 2013
    Germantown, MD
    Get in touch with Craig here: @mobileparts
  3. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    OK Thanks
  4. C Body Bob
    C Body Bob Old Man with a Hat FCBO Gold Member
    Rating - 100%
    20   0   0
    13,270
    13089
    Apr 8, 2012
    Youngsville, NC
    I have the complete set up from a 74 Newport.
  5. Wollfen
    Wollfen Old Man with a Hat
    Rating - 100%
    4   0   0
    6,754
    3514
    Jul 18, 2012
    Greenville NC
    What are you looking to put the spindles in?
  6. mobileparts
    mobileparts Active Member
    0   0   0
    445
    196
    Jul 24, 2011
    C Body Bob has cars.... I don't....
    I do NEW ONLY --- I am in Long Island, New York ---
    No cutting up of cars out here....
    Spindles are USED only....
    Not my department --- see C Body Bob.....
    Yours, Craig.....
    I have N.O.S. Asbestos Brake Pads , if you get what you want or need.......
    • Like Like x 1
  7. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    Ok thanks
  8. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    I'm putting the heavy duty C Body brake system on a 1968 Dodge Charger with some mods.
  9. Wollfen
    Rating - 100%
    4   0   0
    6,754
    3514
    Jul 18, 2012
    Greenville NC
    Ok, my only thoughts on this is the lower ball joint on the cbody should fit if you taper drill the mount hole on your lower control arm. The 74 later spindles are different again as the ball joint is in the lower control arm.
  10. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    I thought about tapering the hole if it isn't too much to where it weakens it. Thanks for the heads up on the 74 spindle. When I looked up the ball joint for it, I saw it was different.
  11. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    Still on the hunt for 1973 C body disc brake spindles.
  12. macgyvernco
    macgyvernco New Member
    0   0   0
    3
    1
    Jun 16, 2018
    Ohio
    Where are you located? Stark Wrecking in Miamisburg Ohio has one 73 Fury and two 72's that still have the brakes on them. They had another 73 but its brakes are in my garage now :) . They will not pull them. You have to go there and get them yourself.
  13. racer383
    racer383 New Member
    Rating - 100%
    1   0   0
    8
    1
    Jul 10, 2020
    usa
    That's too far for me.
    • Like Like x 1
