The mini converters were placed in the y-pipe on single exhaust and in the "head pipe" on dual exhaust cars.
Chrysler and Ford honeycomb monolith converters were generally smaller in size than the GM "bead" converters. But the true "mini" converter was quite a bit smaller in size than the normal Chrysler-spec cat converter.
What "true dual exhaust" means is that each exhaust manifold has a pipe attached to it, which leads to a separate muffler and tail pipe for EACH side. Rather than going into a single, main cat converter and then splits into a "dual outlet" exhaust system (as in the '77-'81 Camaro Z/28s, for example).
On most genuine Police TorqueFlites, there was a "low gear blockout" mechanism. So you effectively only had "P-R-N-D" available. Reason? To prevent a driver from going from "P" to Manual Low when a pursuit was initiated, and continuing on as if the trans was in "D", when it was in "1" instead. So access to any lower gear, manually, was blocked to prevent such a "heat of battle" situation.
As for the plastic bushings melting, it's something that's not going to happen in a short time period, but from longer periods of WOT or extensive idling, while parked in a tail wind situation, possibly.
The Ford Fairmont police vehicles had issues with "smells" from the rear seat foam, during normal patrol work, which was claimed to be from heat from the dual exhaust mufflers under the rear seat area.
I highly suspect that police vehicles which just patrolled and were generally in motion would not produce the situation the TSB describes. There might also have been some pipe clearance issues that also were part of the particular situation, too.
It would be better to lose sleep over the rear tires not "barking" at a WOT 1-2 shift than that linkage bushing melting, to me.
