Comparing this with the back of a 1979 broadcast sheet, your decoding is basically correct. Here it is again, with a few additions in bold type:
FP22:
Unknown > F Carline: Chrysler LeBaron
Unknown > P Price Class: Premium
Unknown > 22 Body: 2-Door Sedan
HG9: Unknown > H Engine: 8-318 4-bbl
Unknown > 9 Model Year: 1979
Windsor, ONT, CAN > G Assembly Plant: St. Louis
153675: Sequence number
E46: Unknown 318 4 BBL
D32: Heavy Duty Automatic Transmission > 998 A/Trans
SG4: Exterior Color Teal Frost Metallic
CFG5: Trim - Charger, Unknown, Unknown Color (CF=Standard Medallion, G5=Teal Green)
000: Full Door Panels > Upper Door Frame Color: not applicable
B13: Build Date: November 13 > Scheduled Production Date: November 13
BQ7202: Order number
SG4: Top Color Teal Frost Metallic
V3G: Unknown V Vinyl & Paint Code? > V3: Landau Vinyl Roof; G: Green
U 3: Unknown Tire/Wheel code? > U: USA Market; 3 Unknown (see comment)
C57: Unknown 60/40 Seats w/Recliner, 3 Piece seating with Center Arm Rest
C97: Trunk Dress-Up
H51: Air Conditioning with Heater
J25: 3 Speed Wipers > Deluxe Windshield Wipers
J52: Inside Hood Release
K5G: Unknown Stipe Code? > K5: Body Side Mldg Type 2; G: Green
L31: Hood/Fender Mounted Turn Signals
L36: Unknown Opera Lamps
L81: Unknown Door Ajar Indicator Lamp
M15: Unknown Upper Door Frame Moldings?
M25: Wide sill moldings > Sill Mldg Type 1
M26: Wheel Lip Moldings
M31: Belt Moldings
N88: Auto Speed Control
N95: Emissions Control > Emiss Test and Label aka California Emissions
P31: Power Windows
R32: Dual Rear Speakers
26: 26in Radiator
END: End of Sales Codes
Some definitions had changed, although they still basically meant the same thing. The confusion surrounding D32 and 000 has been discussed often enough, likewise the wrong description "Build Date".
The big news is that 3 between the market code and the start of the sales codes. All I can say is that it must be assembly plant-specific, because 1979 Dodge Magnum fender tags from Windsor don't show anything in that position.
