commando1
Damn that is very tempting.
32,441 miles showing on digital dash and has spent its entire life in Central Florida. Runs, looks good, has rust on the truck lid otherwise an amazingly rust free vehicle. Under the car is clean, good floors, clean inside the engine compartment. The upholstery on the bottom of both front seats will need to be replaced. This has the factory Carb retrofit as indicated by the (*) in between the numbers on the Odometer. I have the original(not pictured) center-caps with the Imperial name set in the red Chrysler pentagon. This car is all there, you will not have to spend time and money hunting for obscure items. It has new front calipers and brake pads, new idler arm, front end, tie-rods,etc have been serviced and inspected for safe driving. Runs, drives, stops good, shifts good. A project car but a pretty easy one.
Classic, antique, project
$1700 Make an offer Text only, I can not return calls at all.
- text
☎ (386) 882-3992
- reply by email:
[email protected]
