2 Barrel Carb for 1963 Newport
  1. Jayvan1967
    Jayvan1967 New Member
    13
    1
    Apr 24, 2018
    Nebraska
    I have a 1963 Chrysler Newport with a 361. Currently has the original Stromberg WWC-3 2 barrel carb on it that is beyond rebuild and would like to replace with a new carb. It is just a Sunday cruiser and do not want to change the intake to a 4 barrel. What do you guys recommend for a 2 barrel carb that will fit this engine. Thanks
  2. Lee Robinson
    Lee Robinson Member
    176
    28
    Feb 16, 2019
    El Dorado Hills, Ca.
    I sent you a PM. I have this one.
  3. Jayvan1967
    13
    1
    Apr 24, 2018
    Nebraska
    Would like to find a new currently made carb and not have to rebuild one. thanks
  4. polara66hardtop
    polara66hardtop Senior Member
    1,385
    484
    Jan 6, 2014
    Omaha nebraska
    look for a rebuilt 70 -73 360-400 two barrel holley, that will bolt right up. I also have an extra for a 73 360-400 application. But I am sure rebuilts are available.
  5. Big_John
    14,599
    9175
    May 21, 2013
    Marcellus, NY
    @Dana at Woodruff Carbs might have a rebuilt carb or a good core to rebuild.
    Since it's a "Sunday cruiser", keeping an original or close to original carb will keep the headaches in tuning, linkage etc. to a minimum.
  6. Gerald Morris
    Gerald Morris Senior Member
    1,511
    350
    Mar 9, 2016
    Tucson
    Holley still makes 2 barrel carbs, including some 350 cfm ones that should be close to the same capacity as the WWC. Street - Holley
    Some hardware is needed to hook them up. I've thought about one of these for my '66 Newport, but am apt to get a new Edelbrock AVS2.
  7. Steve300
    Steve300 New Member
    4
    2
    Feb 8, 2021
    Von Ormy, TX
  8. Jayvan1967
    13
    1
    Apr 24, 2018
    Nebraska
    Thanks for the input. I will take a look at your suggestions. Thanks
  9. Rooster34
    Rooster34 Member
    166
    114
    May 24, 2020
    Maine
    @Jayvan1967 I have one that came off my 1965 318 poly which was a remanufactured one, probably only has a few hundred miles on it
